メインコンテンツにスキップ
HP Envy x360 15m-bp111dx Hard Drive Replacement
必要な工具と部品
  1. HP Envy x360 15m-bp111dx Hard Drive Replacement, Back Panel: 手順 1、 2の画像 1 HP Envy x360 15m-bp111dx Hard Drive Replacement, Back Panel: 手順 1、 2の画像 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Hard Drive Replacement: 手順 2、 3の画像 1 HP Envy x360 15m-bp111dx Hard Drive Replacement: 手順 2、 3の画像 2 HP Envy x360 15m-bp111dx Hard Drive Replacement: 手順 2、 3の画像 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Hard Drive Replacement, Battery: 手順 3、 2の画像 1 HP Envy x360 15m-bp111dx Hard Drive Replacement, Battery: 手順 3、 2の画像 2
    • Use a Phillips screwdriver to remove the seven 4 mm screws securing the battery.
  4. HP Envy x360 15m-bp111dx Hard Drive Replacement: 手順 4、 3の画像 1 HP Envy x360 15m-bp111dx Hard Drive Replacement: 手順 4、 3の画像 2 HP Envy x360 15m-bp111dx Hard Drive Replacement: 手順 4、 3の画像 3
    • Carefully lift the battery, and pull it towards you to remove it.
  5. HP Envy x360 15m-bp111dx Hard Drive Replacement, Hard Drive: 手順 5、 1の画像 1
    • The hard drive bay is located in the lower left corner of the computer.
    • The hard drive will be covered by a black rubber sheath which can be removed by simply pulling it off of the hard drive (not pictured).
  6. HP Envy x360 15m-bp111dx Hard Drive Replacement: 手順 6、 3の画像 1 HP Envy x360 15m-bp111dx Hard Drive Replacement: 手順 6、 3の画像 2 HP Envy x360 15m-bp111dx Hard Drive Replacement: 手順 6、 3の画像 3
    • Pull the rubber casing away from the drive (not pictured here) and gently lift the hard drive out of the computer.
    • Unplug the drive from power by grabbing the SATA / power cable on the plastic edge and pulling it away from the drive.
    • Do not disconnect the ribbon cable from the motherboard.
  7. HP Envy x360 15m-bp111dx Hard Drive Replacement: 手順 7、 1の画像 1
    • The hard drive is now removed and can be replaced.
終わりに
作成者
5人の作成者と共同で作成されました。
Ross Snead
メンバー登録日: 02/22/22
162 ポイント
1ガイドが承認済み
チーム
Clemson, Team 2-2, Hunter Spring 2022 Clemson, Team 2-2, Hunter Spring 2022人のメンバー
CLEM-HUNTER-S22S2G2
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 21
今までの合計 406
