はじめに
This guide will assist in locating, removing, and replacing the charging port for your HP Envy x360 15m-bp111dx. You may need to replace this component if your laptop is not charging properly. Be sure to troubleshoot your HP Envy x360 15m-bp111dx to ensure that this is not an issue concerning the battery. You can verify this with our troubleshooting guide here.
Be sure that your laptop is powered off, disconnected from the charging adapter, and that the components have cooled before beginning this replacement.
必要な工具と部品
Remove the rubber feet to access the screws.
Using a Phillips #0 screwdriver, remove the four 7 mm screws.
Using a T5 Torx screwdriver, remove the three 5 mm screws.
Use a Phillips #0 screwdriver to remove the two M2x3.1 screws that secure the speaker in place.
Lift and move the speaker to the side.
ある他の人がこのガイドを完成しました。
コメント 1 件
What is a typical charge for a technician to replace the charging port and what should a typical charging port cost?
