メインコンテンツにスキップ
HP Envy x360 15m-bp111dx Charging Port Replacement
必要な工具と部品
  1. HP Envy x360 15m-bp111dx Charging Port Replacement, Back Panel: 手順 1、 2の画像 1 HP Envy x360 15m-bp111dx Charging Port Replacement, Back Panel: 手順 1、 2の画像 2
    • Remove the rubber feet to access the screws.
    • Using a Phillips #0 screwdriver, remove the four 7 mm screws.
    • Using a T5 Torx screwdriver, remove the three 5 mm screws.
  2. HP Envy x360 15m-bp111dx Charging Port Replacement: 手順 2、 3の画像 1 HP Envy x360 15m-bp111dx Charging Port Replacement: 手順 2、 3の画像 2 HP Envy x360 15m-bp111dx Charging Port Replacement: 手順 2、 3の画像 3
    • Insert opening picks or an opening tool inside the edge of the chassis to separate the back panel from the rest of the computer.
    • You may hear snapping as the clips are released while you work your way around the perimeter of the computer. This is normal.
    • Remove the back case.
  3. HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: 手順 3、 3の画像 1 HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: 手順 3、 3の画像 2 HP Envy x360 15m-bp111dx Charging Port Replacement, Charging Port: 手順 3、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the two M2x3.1 screws that secure the speaker in place.
    • Lift and move the speaker to the side.
    • Do not pull too hard on the speaker. It is connected by thin wires that run under the motherboard.
  4. HP Envy x360 15m-bp111dx Charging Port Replacement: 手順 4、 2の画像 1 HP Envy x360 15m-bp111dx Charging Port Replacement: 手順 4、 2の画像 2
    • Use a Phillips #0 screwdriver to remove remove three M2.5x4 screws that secure the hinge.
  5. HP Envy x360 15m-bp111dx Charging Port Replacement: 手順 5、 1の画像 1
    • Use the opening tool to raise the hinge.
    • Then lift the hinge by hand to provide enough clearance to remove the charging port.
    • Be careful when lifting the hinge. The back can be bent and damaged if raised too far.
  6. HP Envy x360 15m-bp111dx Charging Port Replacement: 手順 6、 2の画像 1 HP Envy x360 15m-bp111dx Charging Port Replacement: 手順 6、 2の画像 2
    • Gently slide the charging port connector out of the port, and lift it above the hinge.
  7. HP Envy x360 15m-bp111dx Charging Port Replacement: 手順 7、 3の画像 1 HP Envy x360 15m-bp111dx Charging Port Replacement: 手順 7、 3の画像 2 HP Envy x360 15m-bp111dx Charging Port Replacement: 手順 7、 3の画像 3
    • Grasp the sliding connector on the motherboard and remove it from the socket.
  8. HP Envy x360 15m-bp111dx Charging Port Replacement: 手順 8、 1の画像 1
    • Remove the charging port.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Tori Luongo
メンバー登録日: 02/22/22
268 ポイント
2のガイドは作成済み
チーム
Clemson, Team 2-2, Hunter Spring 2022 Clemson, Team 2-2, Hunter Spring 2022人のメンバー
CLEM-HUNTER-S22S2G2
5 メンバー
6のガイドは作成済み
コメント 1 件
What is a typical charge for a technician to replace the charging port and what should a typical charging port cost?
Robert Ford - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 16
過去 30 日: 31
今までの合計 566
