はじめに
If you are having trouble with the battery life of your device or if your device will not turn on, it may be time for a replacement battery. This guide will provide step-by-step instructions for how to remove the battery on an HP Envy x360 13-y013cl laptop. Be aware of any swelling in the battery as there may be an increased risk of combustion. Before starting the guide, ensure to power off the device, drain the battery to 0 percent, and disconnect the power source.
必要な工具と部品
ある他の人がこのガイドを完成しました。
