メインコンテンツにスキップ
HP Envy TouchSmart 15 Wireless Adapter Replacement
必要な工具と部品
  1. HP Envy TouchSmart 15 Wireless Adapter Replacement, Battery: 手順 1、 1の画像 1
    • Press the battery release tab and the battery will pop up.
  2. HP Envy TouchSmart 15 Wireless Adapter Replacement: 手順 2、 1の画像 1
    • Remove the battery from the laptop, it will come out easily.
  3. HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: 手順 3、 2の画像 1 HP Envy TouchSmart 15 Wireless Adapter Replacement, Accessory Plate: 手順 3、 2の画像 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. HP Envy TouchSmart 15 Wireless Adapter Replacement: 手順 4、 3の画像 1 HP Envy TouchSmart 15 Wireless Adapter Replacement: 手順 4、 3の画像 2 HP Envy TouchSmart 15 Wireless Adapter Replacement: 手順 4、 3の画像 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: 手順 5、 2の画像 1 HP Envy TouchSmart 15 Wireless Adapter Replacement, Wireless Adapter: 手順 5、 2の画像 2
    • Remove the screw with PH 0 screwdriver that is holding the wireless adapter in. This is PM 2.0x2.5 screws.
  6. HP Envy TouchSmart 15 Wireless Adapter Replacement: 手順 6、 3の画像 1 HP Envy TouchSmart 15 Wireless Adapter Replacement: 手順 6、 3の画像 2 HP Envy TouchSmart 15 Wireless Adapter Replacement: 手順 6、 3の画像 3
    • Hold the wireless adapter and gently remove the white and black wires from it. The connectors will come out straight up.
    Hi
    Today I open my laptop to clean up a bit of dust. and by mistakenly I break black connector. not the thing is that the connector part from wireless card stuck inside black cable. but i can still use wifi without any problem. my question is " Is there any affect on my laptop if i leave it like this ?" and another question what is the functioning of that black cable ?
    hope I will get reply soon.please reply me on ronak.r.30588@gmail.com
    Thank you
    Ronak
    Ronnie M - 返信
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Robert Patterson
メンバー登録日: 09/04/15
1,442 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 2-6, Sullivan Fall 2015 USF Tampa, Team 2-6, Sullivan Fall 2015人のメンバー
USFT-SULLIVAN-F15S2G6
4 メンバー
10のガイドは作成済み
コメント 1 件
Hi, I use this exact laptop but my wifi card was changed and it didn’t come with Bluetooth so i wanted to know if this
https://www.aliexpress.com/item/Dual-Ban...
can work for me and if its OK to buy it. Thanks
temidayoabayomizannu - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 3,097
