メインコンテンツにスキップ
HP Envy TouchSmart 15 Digitizer Replacement
必要な工具と部品
  1. HP Envy TouchSmart 15 Digitizer Replacement, Touch Screen/Digitizer: 手順 1、 1の画像 1
    • Lay the laptop down with the bottom facing up.
  2. HP Envy TouchSmart 15 Digitizer Replacement: 手順 2、 1の画像 1
    • Slide the switch to release the battery and remove it.
  3. HP Envy TouchSmart 15 Digitizer Replacement: 手順 3、 2の画像 1 HP Envy TouchSmart 15 Digitizer Replacement: 手順 3、 2の画像 2
    • Remove the screw from the access panel. Gently lift and remove the panel.
  4. HP Envy TouchSmart 15 Digitizer Replacement: 手順 4、 3の画像 1 HP Envy TouchSmart 15 Digitizer Replacement: 手順 4、 3の画像 2 HP Envy TouchSmart 15 Digitizer Replacement: 手順 4、 3の画像 3
    • Remove the hard drive and disconnect its ribbon cable from both the hard drive and the motherboard.
  5. HP Envy TouchSmart 15 Digitizer Replacement: 手順 5、 3の画像 1 HP Envy TouchSmart 15 Digitizer Replacement: 手順 5、 3の画像 2 HP Envy TouchSmart 15 Digitizer Replacement: 手順 5、 3の画像 3
    • Remove the screws to loosen the bottom casing.
    • Remove the two feet to reveal the screws underneath.
  6. HP Envy TouchSmart 15 Digitizer Replacement: 手順 6、 1の画像 1
    • Gently pry the edges to loosen the case.
    • Once loose, lift and remove the plastic casing to reveal the motherboard.
  7. HP Envy TouchSmart 15 Digitizer Replacement: 手順 7、 2の画像 1 HP Envy TouchSmart 15 Digitizer Replacement: 手順 7、 2の画像 2
    • Lift and detach the wireless antenna cables.
    • Lift and de-route the wires from their tracks until you reach the display hinges.
  8. HP Envy TouchSmart 15 Digitizer Replacement: 手順 8、 1の画像 1
    • Detach the two cables. Lift the tab for the ribbon cable before pulling it out.
  9. HP Envy TouchSmart 15 Digitizer Replacement: 手順 9、 2の画像 1 HP Envy TouchSmart 15 Digitizer Replacement: 手順 9、 2の画像 2
    • Remove the screws from each hinge.
    • Lift the hinges with pliers until they are perpendicular to the case.
    • Lift and remove the bottom of the laptop from the screen.
  10. HP Envy TouchSmart 15 Digitizer Replacement: 手順 10、 1の画像 1
    • Lift the tabs in both the bottom corners and remove the screws beneath.
  11. HP Envy TouchSmart 15 Digitizer Replacement: 手順 11、 2の画像 1 HP Envy TouchSmart 15 Digitizer Replacement: 手順 11、 2の画像 2
    • Using a pry tool as necessary, remove the digitizer from the rest of the screen panel. Be careful around the top edge as there are delicate components beneath.
  12. HP Envy TouchSmart 15 Digitizer Replacement: 手順 12、 3の画像 1 HP Envy TouchSmart 15 Digitizer Replacement: 手順 12、 3の画像 2 HP Envy TouchSmart 15 Digitizer Replacement: 手順 12、 3の画像 3
    • Using a heat gun, carefully loosen the adhesive connecting the digitizer to its plastic border.
    • Gently peel the digitizer away from the plastic border.
    • When installing the new one digitizer, press firmly around the edges.
終わりに
5 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Micah Kempf
メンバー登録日: 03/30/16
260 ポイント
1ガイドが承認済み
チーム
Michigan Tech, Team 1-12, Lauer Spring 2016 Michigan Tech, Team 1-12, Lauer Spring 2016人のメンバー
MTU-LAUER-S16S1G12
1 メンバー
1のガイドは作成済み
4 件のコメント
These directions are perfect. I was able to successfully change my digitizer in under an hour
Joe Russo - 返信
where do you get the digitizer?
Jacob - 返信
Amazing,
My name is Nevelson, I have exactly same laptop and mine also is broke, but I don't know where to get the replacement; only the sensor, please I need help and willing to pay handsomely.
Nevelson Odimgbe - 返信
Nevelson, I have updated this page to included a link to the part on amazon.
Micah Kempf - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 21
今までの合計 14,134
