Once all of the screws have come out, flip the laptop over and open the lid so that the keyboard is face up.
Pop the keyboard from the sides and carefully lift it off of the parts underneath.
DO NOT pull the keyboard away from the rest of the laptop too quickly. There are various cords and wires connecting the keyboard section to the rest of the computer that should remain plugged in.
Once the battery is safely removed, plug the charging cord into the charging port on the side and plug the other end into the wall.
DO NOT turn the computer on or touch any of the internal components during this step.
If the light is on after plugging it in, you have just confirmed that something is wrong with the battery, which means you're on the right track!
If the light on the side blinks upon plugging it in, the battery is not the problem. If that is the case, put your laptop back together and consult an expert.
In addition to the screws shown there are two screws under the pads close to the hinges. Pry the pads off and remove the screws under them. Then follow the instructions.
This worked like a charm for me. Thank you for posting!! followed directions exactly, so easy to follow. The only trouble I had was getting the keyboard detached. It was really stuck on there, but I eventually got it. Battery is charging as we speak.
