メインコンテンツにスキップ
HP Envy 700-030qe Solid State Drive Replacement
必要な工具と部品
  1. HP Envy 700-030qe Solid State Drive Replacement, Solid State Drive: 手順 1、 1の画像 1
    • Before beginning, it is good to wear an anti-static wrist band to prevent electrical components from getting harmed.
    • Attach the anti-static wristband to your wrist, and clip the other end to an exposed piece of metal anywhere on the case.
  2. HP Envy 700-030qe Solid State Drive Replacement: 手順 2、 1の画像 1
    • Start by opening the device case by unscrewing the 10.5mm hand screw on the back of the computer.
    • If the hand screw is too tight, you may use the Torx T15 screwdriver to remove it.
  3. HP Envy 700-030qe Solid State Drive Replacement: 手順 3、 1の画像 1
    • Turn the computer onto its side to continue removing the case cover.
    • Slide the cover off by sliding it to the right.
  4. HP Envy 700-030qe Solid State Drive Replacement: 手順 4、 2の画像 1 HP Envy 700-030qe Solid State Drive Replacement: 手順 4、 2の画像 2
    • Locate the SSD inside the open case.
    • Unplug the SATA power cable from the hard drive by pulling straight up.
  5. HP Envy 700-030qe Solid State Drive Replacement: 手順 5、 1の画像 1
    • Finish disconnecting the hard drive by unplugging the black SATA interface cable by pulling up.
  6. HP Envy 700-030qe Solid State Drive Replacement: 手順 6、 1の画像 1
    • To remove the SSD and its casing, pull out on the side silver tab.
    • At the same time, pull up on the hard drive. It should slide out smoothly without much effort.
  7. HP Envy 700-030qe Solid State Drive Replacement: 手順 7、 1の画像 1
    • To completly remove the SSD from its casing, unscrew the four 5mm screws on opposite ends of the casing. Use a Torx T15 screw driver to accomplish this.
    • Notice that the screws to remove are the four screws inside the holes rather than the screws that are next to the holes.
  8. HP Envy 700-030qe Solid State Drive Replacement: 手順 8、 1の画像 1
    • Finally, slide the SSD out of the casing.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Chandler Warne
メンバー登録日: 10/01/15
273 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 5-9, Maness Fall 2015 Cal Poly, Team 5-9, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S5G9
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 20
今までの合計 2,517
