メインコンテンツにスキップ
HP Envy 5660 Scanner Glass Replacement
必要な工具と部品
  1. HP Envy 5660 Scanner Glass Replacement, Scanner Glass: 手順 1、 1の画像 1
    • Open the cartridge access area.
  2. HP Envy 5660 Scanner Glass Replacement: 手順 2、 1の画像 1
    • Remove the three 11.5 mm screws with a T10 bit.
  3. HP Envy 5660 Scanner Glass Replacement: 手順 3、 3の画像 1 HP Envy 5660 Scanner Glass Replacement: 手順 3、 3の画像 2 HP Envy 5660 Scanner Glass Replacement: 手順 3、 3の画像 3
    • Locate the cover hinge on the right side of the printer.
    • Pull the hinge off of the scanner to allow the scanner to open to 90 degress.
  4. HP Envy 5660 Scanner Glass Replacement: 手順 4、 2の画像 1 HP Envy 5660 Scanner Glass Replacement: 手順 4、 2の画像 2
    • Remove the 12 mm screws on the left side of the printer with a T10 bit.
  5. HP Envy 5660 Scanner Glass Replacement: 手順 5、 2の画像 1 HP Envy 5660 Scanner Glass Replacement: 手順 5、 2の画像 2
    • Remove the 11.5 mm screw with a T10 bit to release the spring-loaded hinge.
    • Since this is a compression spring, the hinge will snap downwards as soon as it is loosened.
  6. HP Envy 5660 Scanner Glass Replacement: 手順 6、 3の画像 1 HP Envy 5660 Scanner Glass Replacement: 手順 6、 3の画像 2 HP Envy 5660 Scanner Glass Replacement: 手順 6、 3の画像 3
    • Pull the plastic side cover off of the printer.
    • You may need to lift the printer and push the cover downwards as it is latched onto the bottom of the printer.
    • Plastic opening tools or a metal spudger may also be used.
  7. HP Envy 5660 Scanner Glass Replacement: 手順 7、 1の画像 1
    • Remove the five 11.5 mm screws located at the bottom of the scanner.
    • Steps 3-6 were intended to create easier access to these screws. However, they will still be difficult to reach.
    • The top of the scanner will now easily pull off.
  8. HP Envy 5660 Scanner Glass Replacement: 手順 8、 2の画像 1 HP Envy 5660 Scanner Glass Replacement: 手順 8、 2の画像 2
    • Pry the old scanning glass up with a metal spudger.
    • There are adhesives under the scanning glass. Be careful not to break the glass while removing it.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ryan Steakley
メンバー登録日: 01/23/18
790 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S1-G6, Livingston Winter 2018 Cal Poly, Team S1-G6, Livingston Winter 2018人のメンバー
CPSU-LIVINGSTON-W18S1G6
4 メンバー
10のガイドは作成済み
1件のガイドコメント
Remove an additional three 11.5 mm torx head screws in the same plane as step #4 photo, but near the hinges. This allows the cover hinges to be raised a bit for easier access to the screws removed in step #7. It also makes it easier to remove and reinstall the side cover.
My scanner glass was not broken, but inside surface had a dirty haze that was effecting my scans and needed cleaning. Thanks, I was ready to buy a new scanner.
Rich Monell - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 29
今までの合計 1,754
