メインコンテンツにスキップ
HP Envy 23-d060qd TouchSmart Speaker Replacement
必要な工具と部品
  1. HP Envy 23-d060qd TouchSmart Speaker Replacement, Back Panel: 手順 1、 1の画像 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Speaker Replacement: 手順 2、 1の画像 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Speaker Replacement: 手順 3、 1の画像 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Speaker Replacement, Speakers: 手順 4、 1の画像 1
    • Remove the receiver for the keyboard and mouse with your hands.
  5. HP Envy 23-d060qd TouchSmart Speaker Replacement: 手順 5、 2の画像 1 HP Envy 23-d060qd TouchSmart Speaker Replacement: 手順 5、 2の画像 2
    • Remove the four 17.5mm T15 screws from the speakers.
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate with your hands.
  6. HP Envy 23-d060qd TouchSmart Speaker Replacement: 手順 6、 2の画像 1 HP Envy 23-d060qd TouchSmart Speaker Replacement: 手順 6、 2の画像 2
    • Disconnect the two speaker connections from the motherboard with your hands. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when disconnecting any wired connections. Pulling on the wires can damage them.
  7. HP Envy 23-d060qd TouchSmart Speaker Replacement: 手順 7、 2の画像 1 HP Envy 23-d060qd TouchSmart Speaker Replacement: 手順 7、 2の画像 2
    • Remove the speakers from the computer, and if needed, separate by disconnecting the wires between them.
    • Be gentle when separating wired connections. Pulling on the wires can damage them.
終わりに
作成者
6人の作成者と共同で作成されました。
Zachary Dicks
メンバー登録日: 10/01/15
1,117 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 5-10, Maness Fall 2015 Cal Poly, Team 5-10, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S5G10
4 メンバー
14のガイドは作成済み
コメント 1 件
where to get the replacement speaker???????
Clovis Young - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 1,390
