メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
はじめに
My computer won't play audio even though I've checked all of the connections. How can I have a dance party without any audio? Luckily the party starts in 15 minutes so I have time to replace the speakers.
パーツ
パーツは指定されていません。
  1. Use your hands to unclip the plastic snaps on the back panel of the device.
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. Remove the three 11.5mm PH2 screws from the back panel.
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. Now, take the back panel off by pulling at it gently with your hands.
    • Now, take the back panel off by pulling at it gently with your hands.
  4. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  5. Remove the receiver for the keyboard and mouse with your hands.
    • Remove the receiver for the keyboard and mouse with your hands.
  6. Remove the four 17.5mm T15 screws from the speakers. Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the four 17.5mm T15 screws from the speakers.
    • Remove the five 7.5mm T15 screws from the cover plate.
    • Remove the cover plate with your hands.
  7. Disconnect the two speaker connections from the motherboard with your hands. Use your hands to gently pull the plastic piece at the ends of the wires. Be gentle when disconnecting any wired connections. Pulling on the wires can damage them.
    • Disconnect the two speaker connections from the motherboard with your hands. Use your hands to gently pull the plastic piece at the ends of the wires.
    • Be gentle when disconnecting any wired connections. Pulling on the wires can damage them.
  8. Remove the speakers from the computer, and if needed, separate by disconnecting the wires between them. Be gentle when separating wired connections. Pulling on the wires can damage them.
    • Remove the speakers from the computer, and if needed, separate by disconnecting the wires between them.
    • Be gentle when separating wired connections. Pulling on the wires can damage them.
終わりに
Zachary Dicks
メンバー登録日: 2015年10月01日
1,017 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 5-10, Maness Fall 2015 Cal Poly, Team 5-10, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S5G10
4 メンバー
14のガイドは作成済み
コメント1件
where to get the replacement speaker???????
Clovis Young - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 712
