メインコンテンツにスキップ
HP Envy 17m-ae111dx Hard Drive Replacement
必要な工具と部品
  1. HP Envy 17m-ae111dx Hard Drive Replacement, Back Cover: 手順 1、 1の画像 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop on its back.
  2. HP Envy 17m-ae111dx Hard Drive Replacement: 手順 2、 3の画像 1 HP Envy 17m-ae111dx Hard Drive Replacement: 手順 2、 3の画像 2 HP Envy 17m-ae111dx Hard Drive Replacement: 手順 2、 3の画像 3
    • Remove the plastic covering to the Disk Reader.
    • Locate the small hole on the side of the disk reader. Insert the T5 Torx head screwdriver (or device of similar thickness) to release the covering for the disk reader.
    • If the button on the side is jammed, pry off the covering by using the iFixit Opening Tool.
  3. HP Envy 17m-ae111dx Hard Drive Replacement: 手順 3、 3の画像 1 HP Envy 17m-ae111dx Hard Drive Replacement: 手順 3、 3の画像 2 HP Envy 17m-ae111dx Hard Drive Replacement: 手順 3、 3の画像 3
    • Unscrew all visible screws.
    • Use the T5 Torx Screwdriver and remove the four visible 6.5mm screws on the bottom of the laptop.
    • One 2.5mm screw, is located where the disk reader was once located. Use a Phillips #00 screwdriver to remove the single screw that connects the bottom cover of the laptop to the bottom frame.
  4. HP Envy 17m-ae111dx Hard Drive Replacement: 手順 4、 2の画像 1 HP Envy 17m-ae111dx Hard Drive Replacement: 手順 4、 2の画像 2
    • Pry the gripper completely off to expose the two screws.
    • Remove the 2.5mm screws under the gripper nearest to the hinge using the Phillips #00 screwdriver.
  5. HP Envy 17m-ae111dx Hard Drive Replacement: 手順 5、 3の画像 1 HP Envy 17m-ae111dx Hard Drive Replacement: 手順 5、 3の画像 2 HP Envy 17m-ae111dx Hard Drive Replacement: 手順 5、 3の画像 3
    • Use the iFixit opening tool to pry off the back cover.
    • Ensure that you go all the way around the laptop with the tool to take it off.
  6. HP Envy 17m-ae111dx Hard Drive Replacement, Hard Drive: 手順 6、 3の画像 1 HP Envy 17m-ae111dx Hard Drive Replacement, Hard Drive: 手順 6、 3の画像 2 HP Envy 17m-ae111dx Hard Drive Replacement, Hard Drive: 手順 6、 3の画像 3
    • Unplug the cable that connects the hard drive to the motherboard.
    • Grab from the base of the cable and not from the wire.
  7. HP Envy 17m-ae111dx Hard Drive Replacement: 手順 7、 1の画像 1
    • Remove the hard drive from the device.
終わりに
作成者
2人の作成者と共同で作成されました。
Kyle Fox
メンバー登録日: 09/16/19
293 ポイント
2のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 51
今までの合計 5,231
