メインコンテンツにスキップ
HP Envy 15-u001dx Wireless Network Card Replacement
必要な工具と部品
  1. HP Envy 15-u001dx Wireless Network Card Replacement, HP Envy 15-u001dx Disassembly: 手順 1、 1の画像 1
    • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
    • The two in the front do not have to be removed as there are no screws underneath them.
  2. HP Envy 15-u001dx Wireless Network Card Replacement: 手順 2、 1の画像 1
    • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
  3. HP Envy 15-u001dx Wireless Network Card Replacement: 手順 3、 1の画像 1
    • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
  4. HP Envy 15-u001dx Wireless Network Card Replacement: 手順 4、 1の画像 1
    • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
    • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
  5. HP Envy 15-u001dx Wireless Network Card Replacement: 手順 5、 2の画像 1 HP Envy 15-u001dx Wireless Network Card Replacement: 手順 5、 2の画像 2
    • Use the spudger to detach the two ribbons from their connectors.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  6. HP Envy 15-u001dx Wireless Network Card Replacement, Wireless Network Card: 手順 6、 1の画像 1
    • Remove the Phillips #0 4.5 mm screw from the wireless network card located in the back, right side of the interior.
  7. HP Envy 15-u001dx Wireless Network Card Replacement: 手順 7、 1の画像 1
    • Use the spudger to remove the antenna connector attached to the black wire labeled "1".
  8. HP Envy 15-u001dx Wireless Network Card Replacement: 手順 8、 1の画像 1
    • Detach the antenna connector for the white wire labeled "2".
  9. HP Envy 15-u001dx Wireless Network Card Replacement: 手順 9、 1の画像 1
    • Gently remove the card from its slot by pulling.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Dakota Presley
メンバー登録日: 10/05/16
885 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 9-4, Lacy Fall 2016 USF Tampa, Team 9-4, Lacy Fall 2016人のメンバー
USFT-LACY-F16S9G4
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 577
