メインコンテンツにスキップ
HP Elitebook x360 1040 G5 Screen display Replacement
必要な工具と部品
  1. HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: 手順 1、 3の画像 1 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: 手順 1、 3の画像 2 HP Elitebook x360 1040 G5 Screen display Replacement, Screen display: 手順 1、 3の画像 3
    • Open your laptop.
    • Apply heat to the perimeter of screen display using the low setting on the heat gun or hair dryer. Keep the heat gun at least 6 inches away from the device at all time to prevent damage to other components.
    • Continue to apply heat for 5 to 10 minutes.
  2. HP Elitebook x360 1040 G5 Screen display Replacement: 手順 2、 3の画像 1 HP Elitebook x360 1040 G5 Screen display Replacement: 手順 2、 3の画像 2 HP Elitebook x360 1040 G5 Screen display Replacement: 手順 2、 3の画像 3
    • Using the jimmy tool pry outward on the screen display, starting near one of the top corners.
    • Carefully pry along the perimeter of the display until the screen can be easily removed.
    • Lay the screen face down on the keyboard for the next step.
  3. HP Elitebook x360 1040 G5 Screen display Replacement: 手順 3、 2の画像 1 HP Elitebook x360 1040 G5 Screen display Replacement: 手順 3、 2の画像 2
    • Carefully remove the clear adhesive protector from the smallest ribbon cable, located closest to the laptop hinge.
    • Gently slide the connector out of the harness, moving it towards the side of the laptop with the power button.
  4. HP Elitebook x360 1040 G5 Screen display Replacement: 手順 4、 3の画像 1 HP Elitebook x360 1040 G5 Screen display Replacement: 手順 4、 3の画像 2 HP Elitebook x360 1040 G5 Screen display Replacement: 手順 4、 3の画像 3
    • Carefully remove the clear adhesive protector from the last ribbon cable, located on the large black strip on the back of the screen display.
    • Gently remove the ribbon cable from the harness by moving it toward the laptop hinge.
  5. HP Elitebook x360 1040 G5 Screen display Replacement: 手順 5、 3の画像 1 HP Elitebook x360 1040 G5 Screen display Replacement: 手順 5、 3の画像 2 HP Elitebook x360 1040 G5 Screen display Replacement: 手順 5、 3の画像 3
    • Remove the screen from the laptop.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Tyler A Cobb
メンバー登録日: 09/03/19
321 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S1-G1, Hovde Fall 2019 IUPUI, Team S1-G1, Hovde Fall 2019人のメンバー
IUPUI-HOVDE-F19S1G1
3 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 44
今までの合計 1,514
