はじめに
Use this guide if you are experiencing issues with your laptop’s fan. These include your device overheating, fans making noise and throttling, or your laptop’s performance dropping. This guide includes instructions to remove and replace your laptop’s fan. Note that removing the fan requires the application of new thermal paste.
必要な工具と部品
Use the T5 Torx screwdriver to remove the six 4 mm screws from the underside of the laptop.
もう少しです!
- To reassemble your device, follow these instructions in reverse order.
終わりに
ある他の人がこのガイドを完成しました。
