メインコンテンツにスキップ
HP Elitebook 8460p Speaker Assembly Replacement
必要な工具と部品
  1. HP Elitebook 8460p Speaker Assembly Replacement, Battery: 手順 1、 1の画像 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Speaker Assembly Replacement: 手順 2、 1の画像 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Speaker Assembly Replacement, Back Panel: 手順 3、 1の画像 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Speaker Assembly Replacement: 手順 4、 1の画像 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Speaker Assembly Replacement, CPU Cooling Fan: 手順 5、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement, CPU Cooling Fan: 手順 5、 2の画像 2
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws on opposite corners of the fan.
  6. HP Elitebook 8460p Speaker Assembly Replacement: 手順 6、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 6、 2の画像 2
    • Pull the fan straight up and to the side slightly.
  7. HP Elitebook 8460p Speaker Assembly Replacement: 手順 7、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 7、 2の画像 2
    • Disconnect the small electrical connector. Pry the edge up with your finger nails or using a small plastic pry tool.
  8. HP Elitebook 8460p Speaker Assembly Replacement: 手順 8、 1の画像 1
    • Using a Phillips #0 bit, unscrew the six screws on the heat sink.
  9. HP Elitebook 8460p Speaker Assembly Replacement: 手順 9、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 9、 2の画像 2
    • Pry the inside edge up, pulling the entire assembly to the inside of the laptop, exposing the processor and graphics processor
    • Clean and replace the thermal paste on the processor if you have any thermal paste.
  10. HP Elitebook 8460p Speaker Assembly Replacement: 手順 10、 1の画像 1
    • Blow compressed air through the vent from the outside and through the heat sink.
  11. HP Elitebook 8460p Speaker Assembly Replacement, Optical Drive: 手順 11、 3の画像 1 HP Elitebook 8460p Speaker Assembly Replacement, Optical Drive: 手順 11、 3の画像 2 HP Elitebook 8460p Speaker Assembly Replacement, Optical Drive: 手順 11、 3の画像 3
    • Using a Phillips #0 bit, unscrew the one Phillips head screw.
    • Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
  12. HP Elitebook 8460p Speaker Assembly Replacement: 手順 12、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 12、 2の画像 2
    • With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
  13. HP Elitebook 8460p Speaker Assembly Replacement: 手順 13、 3の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 13、 3の画像 2 HP Elitebook 8460p Speaker Assembly Replacement: 手順 13、 3の画像 3
    • Skip this step if you are removing the optical drive to fix or replace a different component in the laptop.
    • Using a small paper clip, push the paper clip straight in to open the optical drive.
  14. HP Elitebook 8460p Speaker Assembly Replacement: 手順 14、 3の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 14、 3の画像 2 HP Elitebook 8460p Speaker Assembly Replacement: 手順 14、 3の画像 3
    • Using a small point, pop the tab out.
    • Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
  15. HP Elitebook 8460p Speaker Assembly Replacement, Hard Drive: 手順 15、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement, Hard Drive: 手順 15、 2の画像 2
    • Pull the tab with the small engraved arrow up and towards the inside of the laptop.
  16. HP Elitebook 8460p Speaker Assembly Replacement: 手順 16、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 16、 2の画像 2
    • Using a Phillips #0 bit, unscrew the three screws that hold the hard drive assembly in place.
  17. HP Elitebook 8460p Speaker Assembly Replacement: 手順 17、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 17、 2の画像 2
    • Remove the silver metal cover by pulling straight up on the black tab.
  18. HP Elitebook 8460p Speaker Assembly Replacement: 手順 18、 1の画像 1
    • Disconnect the hard drive by pulling the drive straight out to the left.
    • If replacing the hard drive, seat the new hard drive firmly in the connector.
  19. HP Elitebook 8460p Speaker Assembly Replacement, Speaker Assembly: 手順 19、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement, Speaker Assembly: 手順 19、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the two 3.0mm screws holding the speaker assembly in place.
  20. HP Elitebook 8460p Speaker Assembly Replacement: 手順 20、 1の画像 1
    • Grasping one corner with two fingers, lift the speaker assembly up and out of the laptop.
  21. HP Elitebook 8460p Speaker Assembly Replacement: 手順 21、 3の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 21、 3の画像 2 HP Elitebook 8460p Speaker Assembly Replacement: 手順 21、 3の画像 3
    • Using a T2 Torx screwdriver, remove the six 8.0mm Torx screws.
    • Four of the Torx screws are located on the four corners of the laptop and the other two are next to the hard drive assembly.
  22. HP Elitebook 8460p Speaker Assembly Replacement: 手順 22、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 22、 2の画像 2
    • Using a Phillips #0 screwdriver, unscrew the Phillips screw next to the fan assembly.
  23. HP Elitebook 8460p Speaker Assembly Replacement: 手順 23、 3の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 23、 3の画像 2 HP Elitebook 8460p Speaker Assembly Replacement: 手順 23、 3の画像 3
    • Using a Philips #0 screwdriver, unscrew the two Phillips screws next to the battery.
  24. HP Elitebook 8460p Speaker Assembly Replacement: 手順 24、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 24、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the three 2.0mm Phillips screws underneath the battery.
  25. HP Elitebook 8460p Speaker Assembly Replacement: 手順 25、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 25、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the two 3.0mm Phillips screws to the right of the optical drive slot
  26. HP Elitebook 8460p Speaker Assembly Replacement: 手順 26、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 26、 2の画像 2
    • Using a Phillips #0 screwdriver, remove the two 2.0mm Phillips screws underneath the hard drive assembly.
  27. HP Elitebook 8460p Speaker Assembly Replacement: 手順 27、 3の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 27、 3の画像 2 HP Elitebook 8460p Speaker Assembly Replacement: 手順 27、 3の画像 3
    • Using a T2 Torx screwdriver, remove the four 8.0mm Torx screws on the back side of the laptop.
  28. HP Elitebook 8460p Speaker Assembly Replacement: 手順 28、 3の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 28、 3の画像 2 HP Elitebook 8460p Speaker Assembly Replacement: 手順 28、 3の画像 3
    • Using a spudger, work your way around the edge of the laptop popping the plastic chassis up.
  29. HP Elitebook 8460p Speaker Assembly Replacement: 手順 29、 2の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 29、 2の画像 2
    • Lift the chassis up and detach the small connector between the hard drive and heat sink.
  30. HP Elitebook 8460p Speaker Assembly Replacement: 手順 30、 3の画像 1 HP Elitebook 8460p Speaker Assembly Replacement: 手順 30、 3の画像 2 HP Elitebook 8460p Speaker Assembly Replacement: 手順 30、 3の画像 3
    • Disconnect the speaker connector from the motherboard.
    • Remove the old speaker assembly and connect the wire for the new speaker assembly in the same location.
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Garrett Anderson
メンバー登録日: 09/16/19
2,250 ポイント
10のガイドは作成済み
チーム
2件のガイドコメント
Thanks for the tutorial. I skipped step 11 - 29 and just cut the wire of the old speakers on both ends. Put in the new speaker and hid the wire under the lid of the hard drive. Looking back.. I could have done this straight away after step 5. Removing the fan and heat sinc isn't necessary if onne's going to cut the wire. Nevertheless, taking out the fan was good to remove all the dust in front of the outlet.
Thanks again!
JJJJJJJJJJJ - 返信
Thanks for your idea..I have searching easy way for it 🙏
Muditha Mahanama -
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 68
今までの合計 5,484
