メインコンテンツにスキップ
HP Elitebook 8460p Cooling Fan Replacement
必要な工具と部品
  1. HP Elitebook 8460p Cooling Fan Replacement, Battery: 手順 1、 1の画像 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Cooling Fan Replacement: 手順 2、 1の画像 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Cooling Fan Replacement, Back Panel: 手順 3、 1の画像 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Cooling Fan Replacement: 手順 4、 1の画像 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: 手順 5、 2の画像 1 HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: 手順 5、 2の画像 2
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws on opposite corners of the fan.
  6. HP Elitebook 8460p Cooling Fan Replacement: 手順 6、 2の画像 1 HP Elitebook 8460p Cooling Fan Replacement: 手順 6、 2の画像 2
    • Pull the fan straight up and to the side slightly.
  7. HP Elitebook 8460p Cooling Fan Replacement: 手順 7、 2の画像 1 HP Elitebook 8460p Cooling Fan Replacement: 手順 7、 2の画像 2
    • Disconnect the small electrical connector. Pry the edge up with your finger nails or using a small plastic pry tool.
  8. HP Elitebook 8460p Cooling Fan Replacement: 手順 8、 1の画像 1
    • Using a Phillips #0 bit, unscrew the six screws on the heat sink.
  9. HP Elitebook 8460p Cooling Fan Replacement: 手順 9、 2の画像 1 HP Elitebook 8460p Cooling Fan Replacement: 手順 9、 2の画像 2
    • Pry the inside edge up, pulling the entire assembly to the inside of the laptop, exposing the processor and graphics processor
    • Clean and replace the thermal paste on the processor if you have any thermal paste.
  10. HP Elitebook 8460p Cooling Fan Replacement: 手順 10、 1の画像 1
    • Blow compressed air through the vent from the outside and through the heat sink.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Garrett Anderson
メンバー登録日: 09/16/19
2,184 ポイント
10のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 47
今までの合計 4,463
