メインコンテンツにスキップ
HP Elitebook 6930p RAM (Expansion Slot) Replacement
必要な工具と部品
  1. HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: 手順 1、 3の画像 1 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: 手順 1、 3の画像 2 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: 手順 1、 3の画像 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): 手順 2、 2の画像 1 HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): 手順 2、 2の画像 2
    • Locate the RAM expansion slot cover on the bottom of the laptop
    • Loosen the PM2.0×5.0 captive screw and remove the cover.
  3. HP Elitebook 6930p RAM (Expansion Slot) Replacement: 手順 3、 2の画像 1 HP Elitebook 6930p RAM (Expansion Slot) Replacement: 手順 3、 2の画像 2
    • Install RAM module into the RAM slot on an angle of around 30 degrees
    • Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
    • Check to ensure the metal tabs are holding the RAM module down on both sides
    • Reinstall the RAM cover
終わりに
8 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Richdave
メンバー登録日: 04/09/10
32,150 ポイント
30のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,545のガイドは作成済み
17 件のコメント
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Jan Cerenohorsky - 返信
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Jan Cerenohorsky -
Yes under the Keyboard and the Max is 8GB DDR2 6400
dcliddle - 返信
Can you add an 8GB DDR2 6400 to your laptop (HP6930p) without upgrading or changing the factory installed one? The label on the bottom of mine says C2D P8700 2.53 GHz 4GB.
Thanks for any help!
Brian Fenech - 返信
Thank you for information.
By p8slot.com
sutep Fifa - 返信
Thanks for such amazing stuff. Please keep sharing.
<a href="https://168slotxo.net/the-secert-slot-on...>ความลับของสล็อตออนไลน์ในคาสิโน</a>
Shoaib - 返信
Thanks for such an amazing stuff. Please keep sharing.
<a href="https://168slotxo.net/168slotxo-the-best...>สล็อตออนไลน์</a>
Shoaib - 返信
You always share so amazing articles. I really love it.
slotxo
Shoaib - 返信
You always share so amazing articles. I love it.
slotxo
Shoaib - 返信
I am a big fan of your site and content.
pg
Shoaib - 返信
I am a big fan of your site and amazing content.
pgslot
Shoaib - 返信
Your content is always awesome.
pg
Shoaib - 返信
Your site is awesome. I will recommend this to everyone.
pg slot
Shoaib - 返信
Thanks for this information, please can i add 8gb to my expansion slot and leave the other 2gb that is under the keyboard?
Emeba Okeoghene - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 48
今までの合計 15,546
