メインコンテンツにスキップ
HP EliteOne 800 G1 Power Supply Replacement
必要な工具と部品
  1. HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: 手順 1、 3の画像 1 HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: 手順 1、 3の画像 2 HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: 手順 1、 3の画像 3
    • Place computer with the screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: 手順 2、 2の画像 1 HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: 手順 2、 2の画像 2
    • Press locking latch on the bottom of the base of the stand.
    • Pull the plastic cover off of the stand.
  3. HP EliteOne 800 G1 Power Supply Replacement: 手順 3、 2の画像 1 HP EliteOne 800 G1 Power Supply Replacement: 手順 3、 2の画像 2
    • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
    • Tilt stand and lift up to remove it.
  4. HP EliteOne 800 G1 Power Supply Replacement: 手順 4、 2の画像 1 HP EliteOne 800 G1 Power Supply Replacement: 手順 4、 2の画像 2
    • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
    • Pull the back panel toward the bottom of the device to remove it.
  5. HP EliteOne 800 G1 Power Supply Replacement, Power Supply: 手順 5、 2の画像 1 HP EliteOne 800 G1 Power Supply Replacement, Power Supply: 手順 5、 2の画像 2
    • Use a Torx T15 driver to remove the four 10mm screws on the VESA mount cover.
    • Lift up on the VESA mount cover to remove it.
  6. HP EliteOne 800 G1 Power Supply Replacement: 手順 6、 1の画像 1
    • Disconnect the power supply's black and yellow cable from the motherboard.
  7. HP EliteOne 800 G1 Power Supply Replacement: 手順 7、 2の画像 1 HP EliteOne 800 G1 Power Supply Replacement: 手順 7、 2の画像 2
    • Use a Torx T15 driver to remove the two 8mm screws on either side of the power supply.
    • Lift the power supply from the case to remove it.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Michael Ewing
メンバー登録日: 10/01/15
1,071 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 1-24, Maness Fall 2015 Cal Poly, Team 1-24, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S1G24
4 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 52
今までの合計 5,302
