メインコンテンツにスキップ
HP EliteBook x360 830 G7 Fan Replacement
必要な工具と部品
  1. HP EliteBook x360 830 G7 Fan Replacement, Remove the backplate: 手順 1、 3の画像 1 HP EliteBook x360 830 G7 Fan Replacement, Remove the backplate: 手順 1、 3の画像 2 HP EliteBook x360 830 G7 Fan Replacement, Remove the backplate: 手順 1、 3の画像 3
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Fan Replacement, Disconnect the bundled cable connector: 手順 2、 1の画像 1
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Fan Replacement, Peel the copper foil tape: 手順 3、 2の画像 1 HP EliteBook x360 830 G7 Fan Replacement, Peel the copper foil tape: 手順 3、 2の画像 2
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Fan Replacement, Remove the screws: 手順 4、 2の画像 1 HP EliteBook x360 830 G7 Fan Replacement, Remove the screws: 手順 4、 2の画像 2
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Fan Replacement, Remove the battery: 手順 5、 3の画像 1 HP EliteBook x360 830 G7 Fan Replacement, Remove the battery: 手順 5、 3の画像 2 HP EliteBook x360 830 G7 Fan Replacement, Remove the battery: 手順 5、 3の画像 3
    • Remove the battery from the laptop.
  6. HP EliteBook x360 830 G7 Fan Replacement, Display panel cable: 手順 6、 1の画像 1
    • Disconnect the display panel cable from it's connector on the motherboard.
  7. HP EliteBook x360 830 G7 Fan Replacement, Necessities that help keep the fan in place: 手順 7、 1の画像 1
    • Remove the display panel and the wireless antenna cables from the routing channels. Then, remove the retention tape from the system fan.
  8. HP EliteBook x360 830 G7 Fan Replacement, Loosen the screws: 手順 8、 1の画像 1
    • Loosen the JIS #1 screws that secure the system fan to the motherboard.
    • These screws are captive.
  9. HP EliteBook x360 830 G7 Fan Replacement, Remove the fan: 手順 9、 2の画像 1 HP EliteBook x360 830 G7 Fan Replacement, Remove the fan: 手順 9、 2の画像 2
    • Once all of the connectors and screws that secure the fan in place have been removed sucessfully, you can safely remove the system fan from the motherboard.
終わりに
作成者
5人の作成者と共同で作成されました。
Taleb Tahous
メンバー登録日: 03/21/22
109 ポイント
1ガイドが承認済み
チーム
University of Alabama, Team 2-1, Bedsole Spring 2022 University of Alabama, Team 2-1, Bedsole Spring 2022人のメンバー
UA-BEDSOLE-S22S2G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 47
今までの合計 698
