はじめに
This guide will show you how to replace the battery of a HP EliteBook x360 830 G5. In order to understand the key steps of removing the base, battery and other elements it is important to follow proper guidelines so that the device is not damaged.
First and foremost, the system needs to be shut down, unplugged, and the battery charge should be lower than 20%.
必要な工具と部品
With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
ある他の人がこのガイドを完成しました。
