はじめに
If your laptop is overheating and there is no fan noise, it may be in need of a fan replacement. Follow these steps to do so.
必要な工具と部品
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
4 の人々がこのガイドを完成させました。
