はじめに
If your drive has some cells that are corrupted or is failed to hold any data, that it must be replaced. This is a guide to replacing the solid state drive of your computer. In order to replace it, the back cover of the laptop must be removed to expose the screw which secures the solid state drive.
Please remember to power down your computer and unplug it to avoid any power surges or shorts. Failing to power down and disconnect the power cable may result in further harm to the laptop or even yourself, so precautions must be taken.
必要な工具と部品
手順1 Lower Case
注意: 手順 1-2 は、作業進行中としてマークされている ガイド から引用されています。
Use a TR8 Torx screwdriver to remove:
Six 5.3 mm screws
Four 3.3 mm screws
Use a Phillips #1 screwdriver to remove the single 1.8 mm screw that secures the SSD to the board.
