はじめに
This guide is intended to illustrate the process of removing a motherboard from an HP Elitebook Folio 1020 G1 so that it can be replaced.
Before taking any part of the computer apart, please remember to power down your computer and unplug the power cable from any power source. Failure to do so could harm yourself or the computer, so these precautions must be taken.
必要な工具と部品
手順1 Lower Case
注意: 手順 1-2 は、作業進行中としてマークされている ガイド から引用されています。
Use a TR8 Torx screwdriver to remove:
Six 5.3 mm screws
Four 3.3 mm screws
Gently pull and free the battery's bundled cable connector that leads from the battery to the motherboard.
Attach terminals in reverse order of guide to new motherboard, reattach the battery and back panel.
