メインコンテンツにスキップ
HP EliteBook 755 G5 Battery Replacement
必要な工具と部品
    • Turn off the computer. If you are unsure whether the computer is in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
  1. HP EliteBook 755 G5 Battery Replacement, Remove the bottom cover: 手順 2、 2の画像 1 HP EliteBook 755 G5 Battery Replacement, Remove the bottom cover: 手順 2、 2の画像 2
    • Turn the computer upside down on a flat surface.
    • Loosen the eight captive screws that secure the bottom cover.
    • Loosen the two inset captive screws that secure the bottom cover.
    • Starting under the middle of the display, pry and lift the bottom cover off the computer.
  2. HP EliteBook 755 G5 Battery Replacement, Disconnect the battery: 手順 3、 1の画像 1
    • Disconnect the battery cable from the system board.
    • Remove the four Torx T8 2.0×4.0 screws.
  3. HP EliteBook 755 G5 Battery Replacement, Remove the battery: 手順 4、 1の画像 1
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
終わりに
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
メンバー登録日: 04/22/20
40,418 ポイント
16のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
140 メンバー
18,115のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 25
今までの合計 1,181
