メインコンテンツにスキップ
HP EliteBook 745 G6 RAM Replacement
必要な工具と部品
  1. HP EliteBook 745 G6 RAM Replacement, RAM: 手順 1、 1の画像 1
    • Type CMD in the Start Menu and open Command Prompt.
    • Type the following command to view memory details and press Enter.
    • wmic memorychip get devicelocator, manufacturer, partnumber, serialnumber, capacity, speed, memorytype, formfactor.
  2. HP EliteBook 745 G6 RAM Replacement: 手順 2、 1の画像 1
    • Power off the Notebook.
    • Select the Start button.
    • Select the Power button.
    • Select Shut down.
    • Disconnect the power adapter.
  3. HP EliteBook 745 G6 RAM Replacement: 手順 3、 2の画像 1 HP EliteBook 745 G6 RAM Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • Turn the notebook upside down on a flat surface.
    • Loosen the six captive screws and the two inset captive screws counter-clockwise with the Phillips #00 screwdriver.
    • Pry the bottom cover with plastic card or spudger at the bottom right corner.
    • Lift the bottom cover off with plastic card.
  4. HP EliteBook 745 G6 RAM Replacement: 手順 4、 2の画像 1 HP EliteBook 745 G6 RAM Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
  5. HP EliteBook 745 G6 RAM Replacement: 手順 5、 2の画像 1 HP EliteBook 745 G6 RAM Replacement: 手順 5、 2の画像 2
    • Be sure to ground yourself by wearing anti-static wrist strap.
    • Do not remove memory shielding from the system board when replacing memory.
    • The socket labeled 2 houses the expansion memory module and the socket labeled 1 houses the primary memory module.
    • Spread the retaining tabs on each side of the memory module slot to release the memory module.
    • Pull the memory module away from the slot at an angle.
  6. HP EliteBook 745 G6 RAM Replacement: 手順 6、 2の画像 1 HP EliteBook 745 G6 RAM Replacement: 手順 6、 2の画像 2
    • Insert the memory module into the slot at an angle.
    • Push down the center of memory module until the retaining tabs lock the RAM stick.
  7. HP EliteBook 745 G6 RAM Replacement: 手順 7、 1の画像 1
    • Insert the battery cable into the system board.
  8. HP EliteBook 745 G6 RAM Replacement: 手順 8、 2の画像 1 HP EliteBook 745 G6 RAM Replacement: 手順 8、 2の画像 2
    • Push down the bottom cover at the four corner and center.
    • Tighten the six captive screws and the two inset captive screws clockwise with Phillips #00 screwdriver.
  9. HP EliteBook 745 G6 RAM Replacement: 手順 9、 1の画像 1
    • Push the power button.
  10. HP EliteBook 745 G6 RAM Replacement: 手順 10、 2の画像 1 HP EliteBook 745 G6 RAM Replacement: 手順 10、 2の画像 2
    • Right-click on the taskbar.
    • Select the “Task Manager”.
    • Select the "Performance".
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Mengqi Shi
メンバー登録日: 05/05/21
208 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G27, O'Regan Summer 2021 York University, Team S1-G27, O'Regan Summer 2021人のメンバー
YORK-O'REGAN-SU21S1G27
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 16
過去 30 日: 68
今までの合計 2,216
