はじめに
This guide will show the reader how to replace the keyboard panel on the HP EliteBook 1050 G1. The keyboard panel is used to type letters on the computer screen. The keyboard replacement is not very difficult, so it has been labeled as "easy", and this task only takes about 10 minutes to complete. To prevent any danger, the battery has been removed. The tools required are shown in the section named "what you need" located to the right of the introduction.
必要な工具と部品
Remove the two 5.5mm screws with a Torx T8 driver.
Remove the five 8.7mm screws with a Torx T8 driver.
Remove the two 6.6mm screws with a Torx T8 driver.
Pry open the backplate with a Jimmy.
Remove two 1.9mm screws from the display cable bracket using a Phillips #00 driver.
Remove the two connectors on the right side gently.
Remove the connector on right side of motherboard.
Remove the three 4.5mm screws using a Phillips #00 driver and remove the bracket.
Remove the two coaxial cables.
