メインコンテンツにスキップ
HP Elite x2 G1 1012 Rear Facing Camera Replacement
必要な工具と部品
  1. HP Elite x2 G1 1012 Rear Facing Camera Replacement, Display: 手順 1、 1の画像 1
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 2、 2の画像 1 HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 2、 2の画像 2
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 3、 1の画像 1
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 4、 2の画像 1 HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 4、 2の画像 2
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 5、 3の画像 1 HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 5、 3の画像 2 HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 5、 3の画像 3
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 6、 2の画像 1 HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 6、 2の画像 2
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
  7. HP Elite x2 G1 1012 Rear Facing Camera Replacement, Rear Facing Camera: 手順 7、 1の画像 1
    この手順で使用する道具:
    購入する
    • Use a pair of tweezers to remove the flex cable on the top of the camera.
  8. HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 8、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the screw in the corner of the camera.
  9. HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 9、 1の画像 1
    • Use a spudger to delicately lift up the camera.
  10. HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 10、 2の画像 1 HP Elite x2 G1 1012 Rear Facing Camera Replacement: 手順 10、 2の画像 2
    • Use a pair of tweezers to disconnect the flex cable from the motherboard and remove the rear facing camera from the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Colin Mika
メンバー登録日: 04/19/18
943 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team S24-G7, Maness Spring 2018 Cal Poly, Team S24-G7, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S24G7
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 14
今までの合計 552
