メインコンテンツにスキップ
HP Elite x2 1012 G2 Wi-Fi Card Replacement
必要な工具と部品
  1. HP Elite x2 1012 G2 Wi-Fi Card Replacement, Screen: 手順 1、 1の画像 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 2、 3の画像 1 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 2、 3の画像 2 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 2、 3の画像 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 3、 2の画像 1 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 3、 2の画像 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 4、 1の画像 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 5、 3の画像 1 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 5、 3の画像 2 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 5、 3の画像 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 6、 2の画像 1 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 6、 2の画像 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Wi-Fi Card Replacement, Wi-Fi Card: 手順 7、 1の画像 1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 8、 3の画像 1 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 8、 3の画像 2 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 8、 3の画像 3
    • Detach the two wire connections on the upper right of the wi-fi card by hand.
  9. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 9、 2の画像 1 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 9、 2の画像 2
    • Use a Phillips 2mm screwdriver to remove the single M2 2.0x2.0 screw holding the wi-fi card in place. Turn the screwdriver counterclockwise to remove the screw.
  10. HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 10、 2の画像 1 HP Elite x2 1012 G2 Wi-Fi Card Replacement: 手順 10、 2の画像 2
    • Slide the wi-fi card out by hand, lifting the card up and out of the device.
    • If it doesn't come out immediately, slowly wiggle the card side to side until it slides out of its connector.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Nathan Diekema
メンバー登録日: 04/18/18
294 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S18G5
4 メンバー
13のガイドは作成済み
コメント 1 件
Hi is it to upgrade the broadband to support 4g lte? Mine unit when inserted 4g data sim card, only can run edge signal. Spec of the broadband is hp hs3210 hspa+
Kenny Liew - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 36
今までの合計 2,291
