メインコンテンツにスキップ
HP Elite x2 1012 G2 Speakers Replacement
必要な工具と部品
  1. HP Elite x2 1012 G2 Speakers Replacement, Screen: 手順 1、 1の画像 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Speakers Replacement: 手順 2、 3の画像 1 HP Elite x2 1012 G2 Speakers Replacement: 手順 2、 3の画像 2 HP Elite x2 1012 G2 Speakers Replacement: 手順 2、 3の画像 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Speakers Replacement: 手順 3、 2の画像 1 HP Elite x2 1012 G2 Speakers Replacement: 手順 3、 2の画像 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Speakers Replacement: 手順 4、 1の画像 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Speakers Replacement: 手順 5、 3の画像 1 HP Elite x2 1012 G2 Speakers Replacement: 手順 5、 3の画像 2 HP Elite x2 1012 G2 Speakers Replacement: 手順 5、 3の画像 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Speakers Replacement: 手順 6、 2の画像 1 HP Elite x2 1012 G2 Speakers Replacement: 手順 6、 2の画像 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Speakers Replacement, Speakers: 手順 7、 1の画像 1
    • Identify the speaker locations.
  8. HP Elite x2 1012 G2 Speakers Replacement: 手順 8、 2の画像 1 HP Elite x2 1012 G2 Speakers Replacement: 手順 8、 2の画像 2
    • Remove the antennae connections from both the WiFi card and the wireless cellular M.2 card.
    • Gently pull the black and red wire free at the motherboard connector.
  9. HP Elite x2 1012 G2 Speakers Replacement: 手順 9、 3の画像 1 HP Elite x2 1012 G2 Speakers Replacement: 手順 9、 3の画像 2 HP Elite x2 1012 G2 Speakers Replacement: 手順 9、 3の画像 3
    • Use the spudger tool to remove the speakers from the housing.
  10. HP Elite x2 1012 G2 Speakers Replacement: 手順 10、 2の画像 1 HP Elite x2 1012 G2 Speakers Replacement: 手順 10、 2の画像 2
    • On the right speaker, the black antena piece must be removed before the speaker can be accessed.
  11. HP Elite x2 1012 G2 Speakers Replacement: 手順 11、 2の画像 1 HP Elite x2 1012 G2 Speakers Replacement: 手順 11、 2の画像 2
    • Now remove the green and white wires from the cable management track and the speakers will be completely removed from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
WesleyEagleson
メンバー登録日: 04/06/19
431 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S13-G13, Wilson Spring 2019 IUPUI, Team S13-G13, Wilson Spring 2019人のメンバー
IUPUI-WILSON-S19S13G13
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 46
今までの合計 1,286
