はじめに
If your rear-facing camera on your HP Elite x2 1012 G2 is broken or not working properly, this guide will walk you through replacing it. Before using this guide, make sure that the rear camera is the source of your problems by troubleshooting the symptoms. Doing the replacement yourself does not require any special skills and only takes a little of your time.
必要な工具と部品
Locate the cameras at the top center of the power and processing unit.
Use a Phillips #00 screwdriver to remove the single 3 mm screw.
Use a spudger tool to lift up the ribbon cable clamps.
