メインコンテンツにスキップ
HP Elite x2 1012 G2 Front Webcam Replacement
必要な工具と部品
  1. HP Elite x2 1012 G2 Front Webcam Replacement, Screen: 手順 1、 1の画像 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Front Webcam Replacement: 手順 2、 3の画像 1 HP Elite x2 1012 G2 Front Webcam Replacement: 手順 2、 3の画像 2 HP Elite x2 1012 G2 Front Webcam Replacement: 手順 2、 3の画像 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Front Webcam Replacement: 手順 3、 2の画像 1 HP Elite x2 1012 G2 Front Webcam Replacement: 手順 3、 2の画像 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Front Webcam Replacement: 手順 4、 1の画像 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Front Webcam Replacement: 手順 5、 3の画像 1 HP Elite x2 1012 G2 Front Webcam Replacement: 手順 5、 3の画像 2 HP Elite x2 1012 G2 Front Webcam Replacement: 手順 5、 3の画像 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Front Webcam Replacement: 手順 6、 2の画像 1 HP Elite x2 1012 G2 Front Webcam Replacement: 手順 6、 2の画像 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Front Webcam Replacement, Front Webcam: 手順 7、 1の画像 1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Front Webcam Replacement: 手順 8、 3の画像 1 HP Elite x2 1012 G2 Front Webcam Replacement: 手順 8、 3の画像 2 HP Elite x2 1012 G2 Front Webcam Replacement: 手順 8、 3の画像 3
    • Remove the wire connector to the front webcam using a plastic opening tool. Hook the tool underneath the connector and pull up and back.
  9. HP Elite x2 1012 G2 Front Webcam Replacement: 手順 9、 1の画像 1
    • Remove the connector immediately to the left of the front webcam's connector. Use a plastic opening tool to gently lift the connector up and out.
  10. HP Elite x2 1012 G2 Front Webcam Replacement: 手順 10、 1の画像 1
    • Remove the connector immediately to the right of the front webcam's connector. Use a plastic opening tool to gently lift the connector up and out.
  11. HP Elite x2 1012 G2 Front Webcam Replacement: 手順 11、 2の画像 1 HP Elite x2 1012 G2 Front Webcam Replacement: 手順 11、 2の画像 2
    • Use a Phillips screwdriver to remove the Phillips M2.0x2.0 screw to the left of the webcam. Turn the screwdriver counterclockwise to remove the screw.
  12. HP Elite x2 1012 G2 Front Webcam Replacement: 手順 12、 1の画像 1
    • Remove the webcam using a plastic opening tool to lift it up and off.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Noah Stapp
メンバー登録日: 04/18/18
767 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S18-G5, Livingston Spring 2018 Cal Poly, Team S18-G5, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S18G5
4 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 26
今までの合計 2,229
