メインコンテンツにスキップ
HP Elite x2 1012 G2 Cooling Fan Replacement
必要な工具と部品
  1. HP Elite x2 1012 G2 Cooling Fan Replacement, Screen: 手順 1、 1の画像 1
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 2、 3の画像 1 HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 2、 3の画像 2 HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 2、 3の画像 3
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 3、 2の画像 1 HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 3、 2の画像 2
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 4、 1の画像 1
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 5、 3の画像 1 HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 5、 3の画像 2 HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 5、 3の画像 3
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 6、 2の画像 1 HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 6、 2の画像 2
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Cooling Fan Replacement, Battery: 手順 7、 1の画像 1
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 8、 2の画像 1 HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 8、 2の画像 2
    • Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
  9. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 9、 2の画像 1 HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 9、 2の画像 2
    • Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
  10. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 10、 1の画像 1
    • Lift the battery out of the device.
  11. HP Elite x2 1012 G2 Cooling Fan Replacement, Cooling Fan: 手順 11、 1の画像 1
    • Use the spudger tools to lift the copper tape and expose the screws.
  12. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 12、 2の画像 1 HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 12、 2の画像 2
    • Use Phillips #00 screwdriver to remove seven 3 mm screws.
  13. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 13、 1の画像 1
    • Lift the heatsink off the motherboard.
  14. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 14、 1の画像 1
    • Use a Phillips #00 screwdriver to remove the final two 3 mm screws that secure the fan.
  15. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 15、 1の画像 1
    • Use a spudger to lift the fan from the main unit.
  16. HP Elite x2 1012 G2 Cooling Fan Replacement: 手順 16、 1の画像 1
    • Use a spudger to lift the connection for the fan and disconnect the plug from the motherboard.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
WesleyEagleson
メンバー登録日: 04/06/19
431 ポイント
3のガイドは作成済み
チーム
IUPUI, Team S13-G13, Wilson Spring 2019 IUPUI, Team S13-G13, Wilson Spring 2019人のメンバー
IUPUI-WILSON-S19S13G13
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 57
今までの合計 2,381
