はじめに
When your device isn’t properly loading files, the storage may be the issue. This guide will teach you how to replace the SSD in your device.
必要な工具と部品
Flip the device over so the base is facing the ceiling.
Lift up the tablet stand.
Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
Use the Phillips #00 screwdriver to remove the six 2 mm screws.
Gently disconnect the two connectors.
ある他の人がこのガイドを完成しました。
