メインコンテンツにスキップ
HP Elite X2 1013 G3 Solid State Drive Replacement
必要な工具と部品
  1. HP Elite X2 1013 G3 Solid State Drive Replacement, Screen: 手順 1、 1の画像 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Solid State Drive Replacement: 手順 2、 2の画像 1 HP Elite X2 1013 G3 Solid State Drive Replacement: 手順 2、 2の画像 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Solid State Drive Replacement: 手順 3、 2の画像 1 HP Elite X2 1013 G3 Solid State Drive Replacement: 手順 3、 2の画像 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Solid State Drive Replacement: 手順 4、 2の画像 1 HP Elite X2 1013 G3 Solid State Drive Replacement: 手順 4、 2の画像 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Solid State Drive Replacement, Battery: 手順 5、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Solid State Drive Replacement: 手順 6、 1の画像 1
    • Lift the battery out of the housing.
  7. HP Elite X2 1013 G3 Solid State Drive Replacement, Solid State Drive: 手順 7、 1の画像 1
    • Make sure the device is powered off and the battery is removed before continuing!
    • Using the Phillips #00 Screwdriver, remove the single indicated screw.
  8. HP Elite X2 1013 G3 Solid State Drive Replacement: 手順 8、 1の画像 1
    • Gently tilt the drive upward, then firmly pull it out from the motherboard.
    • Pay attention to the orientation of the SSD. Trying to put your replacement SSD in the wrong way could damage the part or the connector.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Kory Haydon
メンバー登録日: 04/18/19
259 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S9-G12, Maness Spring 2019 Cal Poly, Team S9-G12, Maness Spring 2019人のメンバー
CPSU-MANESS-S19S9G12
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 17
過去 30 日: 74
今までの合計 2,722
