はじめに
This guide will show you how to replace the motherboard in an HP Elite X2 1013 G3 tablet.
必要な工具と部品
Flip the device over so the base is facing the ceiling.
Lift up the tablet stand.
Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
Use the Phillips #00 screwdriver to remove the six 2 mm screws.
Gently disconnect the two connectors.
Remove five screws from the heat sink using a Phillips #0 screwdriver.
Remove the heat sink from the tablet.
もう少しです!
終わりに
