はじめに
If your laptops Fingerprint Scanner is damaged or no longer functioning reliably, use this guide to remove and replace it.
必要な工具と部品
Flip the device over so the base is facing the ceiling.
Lift up the tablet stand.
Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
Use the Phillips #00 screwdriver to remove the six 2 mm screws.
Gently disconnect the two connectors.
もう少しです!
終わりに
