はじめに
The panel is what holds the screen in place. Before removing the panel make sure the printer is unplugged.
必要な工具と部品
Use the Metal Spudger from the IFIXIT Toolkit to pry the left corner of the front panel.
Slowly pry the front panel by sliding the Metal Spudger along the border of the front panel.
On some printer version, you may find a single torx 10 screw under the right sticker.
Remove it and then slide the panel to the right then to the top.
Easy as said!
No need to use any spudger.
Learned it the hard way ;)
3 件のコメント
Is the front panel from a 5532 compatible with the Envy 5530?
