この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If the scans or copies made are not matching the desired document, replacing the scanner glass is a solution to consider. There could be a crack or scratch in the glass affecting the quality of the scanned or copied document.
必要な工具と部品
Open the front access panel by placing your finger in the front slot and pulling gently.
Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
3 の人々がこのガイドを完成させました。
