メインコンテンツにスキップ
HP Deskjet GT-5821 Scanner Glass Replacement
必要な工具と部品
  1. HP Deskjet GT-5821 Scanner Glass Replacement, Open front access panel: 手順 1、 1の画像 1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet GT-5821 Scanner Glass Replacement, Top Lid: 手順 2、 1の画像 1
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. HP Deskjet GT-5821 Scanner Glass Replacement: 手順 3、 3の画像 1 HP Deskjet GT-5821 Scanner Glass Replacement: 手順 3、 3の画像 2 HP Deskjet GT-5821 Scanner Glass Replacement: 手順 3、 3の画像 3
    • Remove the four 9mm T10 Torx screws on the top.
  4. HP Deskjet GT-5821 Scanner Glass Replacement: 手順 4、 2の画像 1 HP Deskjet GT-5821 Scanner Glass Replacement: 手順 4、 2の画像 2
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. HP Deskjet GT-5821 Scanner Glass Replacement: 手順 5、 3の画像 1 HP Deskjet GT-5821 Scanner Glass Replacement: 手順 5、 3の画像 2 HP Deskjet GT-5821 Scanner Glass Replacement: 手順 5、 3の画像 3
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
  6. HP Deskjet GT-5821 Scanner Glass Replacement, Remove Back Panel of Lid: 手順 6、 1の画像 1
    • Remove one 9mm T10 Torx screw from the back of the printer lid.
  7. HP Deskjet GT-5821 Scanner Glass Replacement: 手順 7、 2の画像 1 HP Deskjet GT-5821 Scanner Glass Replacement: 手順 7、 2の画像 2
    • Press outward on the plastic tab holding the back panel in place.
  8. HP Deskjet GT-5821 Scanner Glass Replacement: 手順 8、 2の画像 1 HP Deskjet GT-5821 Scanner Glass Replacement: 手順 8、 2の画像 2
    • Pull the back panel towards you and lift it away from the rest of the printer cover.
    • Some ribbon cables may still be inserted through the back panel. Be careful not to damage these and they should slide out easily.
  9. HP Deskjet GT-5821 Scanner Glass Replacement, Scanner Glass: 手順 9、 1の画像 1
    • Remove one 9mm T10 Torx screw from the white retaining tab.
  10. HP Deskjet GT-5821 Scanner Glass Replacement: 手順 10、 1の画像 1
    • Remove the white retaining tab.
  11. HP Deskjet GT-5821 Scanner Glass Replacement: 手順 11、 1の画像 1
    • To remove the scanner glass, gently push it towards you.
    • Slide glass panel until it is completely removed from printer.
    • Use caution when removing glass and be aware of any sharp edges.
終わりに
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Kevin Raives
メンバー登録日: 01/15/13
93 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S18G35
5 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 2,106
