メインコンテンツにスキップ
HP Deskjet F4480 Mother Board Replacement
必要な工具と部品
  1. HP Deskjet F4480 Mother Board Replacement, Open front access panel: 手順 1、 1の画像 1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet F4480 Mother Board Replacement, Top Lid: 手順 2、 1の画像 1
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. HP Deskjet F4480 Mother Board Replacement: 手順 3、 3の画像 1 HP Deskjet F4480 Mother Board Replacement: 手順 3、 3の画像 2 HP Deskjet F4480 Mother Board Replacement: 手順 3、 3の画像 3
    • Remove the four 9mm T10 Torx screws on the top.
  4. HP Deskjet F4480 Mother Board Replacement: 手順 4、 2の画像 1 HP Deskjet F4480 Mother Board Replacement: 手順 4、 2の画像 2
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  5. HP Deskjet F4480 Mother Board Replacement: 手順 5、 3の画像 1 HP Deskjet F4480 Mother Board Replacement: 手順 5、 3の画像 2 HP Deskjet F4480 Mother Board Replacement: 手順 5、 3の画像 3
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
  6. HP Deskjet F4480 Mother Board Replacement, Mother Board: 手順 6、 2の画像 1 HP Deskjet F4480 Mother Board Replacement, Mother Board: 手順 6、 2の画像 2
    • The mother board is located at the back of the printer.
  7. HP Deskjet F4480 Mother Board Replacement: 手順 7、 3の画像 1 HP Deskjet F4480 Mother Board Replacement: 手順 7、 3の画像 2 HP Deskjet F4480 Mother Board Replacement: 手順 7、 3の画像 3
    • Take note of the wire's location and orientation as this will be important to properly reassemble your device.
    • Remove all of the wires connected to the mother board. There are seven in total.
  8. HP Deskjet F4480 Mother Board Replacement: 手順 8、 2の画像 1 HP Deskjet F4480 Mother Board Replacement: 手順 8、 2の画像 2
    • Remove the three 9mm T10 Torx screws that hold the motherboard to the body of the printer
  9. HP Deskjet F4480 Mother Board Replacement: 手順 9、 1の画像 1
    • At this point, the mother board should be free of all connections from the rest of the printer.
    • Remove and replace the mother board with the new one.
終わりに
7 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Allen Bailey
メンバー登録日: 01/15/13
218 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S18G35
5 メンバー
15のガイドは作成済み
3 件のコメント
ok so ineed to replace the Motherboard -- where do I get this board and what is the cost?
Ken Craven - 返信
ou est localiser le sensor encoder module cb781-8006 merci
viateur levesque - 返信
ou est installer le sensor encoder CB781-8006 Merci
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 20
過去 30 日: 33
今までの合計 3,757
