メインコンテンツにスキップ
HP Deskjet F4480 Ink Cartridges Replacement
  1. HP Deskjet F4480 Ink Cartridges Replacement, Open front access panel: 手順 1、 1の画像 1
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. HP Deskjet F4480 Ink Cartridges Replacement, Ink Cartridges: 手順 2、 1の画像 1
    • Slide the ink carriage until the the cartridges line up with the marked slots in the middle.
    • If the printer is on, then the carriage should have automatically slid to the middle when the front was opened. If not, ensure printer is unplugged and slide manually.
  3. HP Deskjet F4480 Ink Cartridges Replacement: 手順 3、 2の画像 1 HP Deskjet F4480 Ink Cartridges Replacement: 手順 3、 2の画像 2
    • Gently, but firmly depress the front of the ink cartridge you are removing until it is loose.
    • There may be a faint click when the cartridge comes loose.
  4. HP Deskjet F4480 Ink Cartridges Replacement: 手順 4、 1の画像 1
    • Gently slide out cartridge.
    • Don't make contact with the ink head. The ink likes to get everywhere.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Tom Higdon
メンバー登録日: 01/15/13
409 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 18-35, Regan Winter 2013 Cal Poly, Team 18-35, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S18G35
5 メンバー
15のガイドは作成済み
4 件のコメント
pls help me to operate to restore my hp deskjet f4480, I removed last wk the catridges to refill but when i starting to put back the catriges, i cant move the catriges holder, give me some tips pls, hoping a lot, ty
rico timbol - 返信
please the drivers may be installed for using the scanner
sarvani valluru -
My daughter took out the ink cartridges on my F4480 hp desk jet and I don’t know how they go in correctly please help
Kelly Cook - 返信
Why don’t you answer my question I just don’t want to force them or rake it
Kelly Cook - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 33
今までの合計 15,705
