はじめに
This guide will replace the gear guard, which will be hidden under the metal frame. It protects the gear from dirt and dust accumulation that would affect the printer's performance.
必要な工具と部品
Remove the five 13.0 mm Torx #10 screws found on top of the frame.
Remove the four 9.0 mm Torx #10 smaller screws.
The gear guard will be located on the left side of the printer.
Grab the plastic guard and lift it up.
ある他の人がこのガイドを完成しました。
