はじめに
A printer’s drivers must be updated to allow it to perform as it was intended to. Updating the drivers and software helps to prevent problems such as a loss of communication with the computer or the inability to compete jobs that are sent to it.
  1. First, you must make sure that the computer has internet access.
    • First, you must make sure that the computer has internet access.
    • Then, check if the printer is plugged in and connected to a computer.
    • To check to see if the computer is connected to the printer open up the Control Panel and click on “view devices and printers”. If the printer is not listed, click add a printer and follow the prompts.
  2. Click here to be redirected to the website, to download the driver update. Select the computer’s operating system, then click next.
    • Click here to be redirected to the website, to download the driver update. Select the computer’s operating system, then click next.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. The browser will redirect to a page labeled “Step two: Select a download”. Click on “Driver – Product Installation Software”.  This will provide a list of the most up-to-date drivers and software installations for the printer.
    • The browser will redirect to a page labeled “Step two: Select a download”. Click on “Driver – Product Installation Software”. This will provide a list of the most up-to-date drivers and software installations for the printer.
    • Note: Other drivers and software are available for different operating systems.
    • Follow the instructions provided by the website, then wait for the site to confirm that the download was successful.
  5. Restart the computer and printer to allow the new software to finish its installation and run properly.
    • Restart the computer and printer to allow the new software to finish its installation and run properly.
まとめ
Now that the printer’s software has been updated, a test sheet should be printed to be sure that it is functioning properly. If there is a problem, be sure to check that the software update did not disconnect the printer from the computer. Directions to check this can be found in Step 1. If problems continue to persist, HP's support website may be able to help and is found at the following link. http://support.hp.com/us-en
Joe
メンバー登録日: 2011年10月14日
1 ポイント
4のガイドは作成済み
チーム
James Madison, Team 2-5, Allen Fall 2011 James Madison, Team 2-5, Allen Fall 2011人のメンバー
JMU-ALLEN-F11S2G5
1 メンバー
4のガイドは作成済み
why photo is missing on step 4 ? please provide photos.
Jenny Jonson - 返信
Why photo is missing from step 4? please provide a picture.
Jenny Jonson - 返信
If you have an Installation CD just insert it to the computer with an operating system that is compatible to use with your printer. Open the setup file and extract the file to the required folder. Select and then carry on with the instructions. Navigate to the control panel to choose the wireless setup wizard. Answer all the instructions of the wizard and move forward with the onscreen instructions that are visible on the device display screen. Navigate to our webpage 123hpcomdj and then speak to our team of experts to know more about the HP DeskJet 6122 Printer setup. Ring the toll-free number and you will get an idea about the device setup and troubleshooting.
hpcomdj - 返信
統計データを表示:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 50
今までの合計 10,727
