メインコンテンツにスキップ
HP Deskjet 3000 j310a Repair Printer Cover Replacement
必要な工具と部品
  1. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Disconnect Printer: 手順 1、 1の画像 1
    • Begin to disassemble the printer by disconnecting from all power sources and computers. Keep cords separate and allow the printer to cool for 5 minutes.
  2. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Remove Bottom Cover: 手順 2、 1の画像 1
    • Flip the printer upside down and locate the cover on the left hand side. It is rectangular shape and is held in place by two screws. Unscrew these screws and take off cover.
  3. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Release Paper Output Tray: 手順 3、 1の画像 1
    • To release the tray from the printer, you must manually pull it out. Hold the tray and push towards one side of the printer. Then pull away from the printer towards the other side. Keep output tray separate.
  4. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Unscrew Cover: 手順 4、 1の画像 1
    • Turn the printer upside down. Locate the four screws holding the cover in place. These will be on the edges of the cover.
  5. HP Deskjet 3000 j310a Repair Printer Cover Replacement: 手順 5、 1の画像 1
    • Unscrew the four screws, keeping them separate. Turn the printer back right side up
  6. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Pull Off Top: 手順 6、 1の画像 1
    • Place fingers on the edge of the red cover. Begin to pull upwards to release the top portion, working your way around the printer. Make sure that it does not fall back into place.
  7. HP Deskjet 3000 j310a Repair Printer Cover Replacement, Disconnect Cover: 手順 7、 2の画像 1 HP Deskjet 3000 j310a Repair Printer Cover Replacement, Disconnect Cover: 手順 7、 2の画像 2
    • Once the top is loose, there will still be a connection wire between the printer and the cover. This wire will be about one inch wide and white, located under the buttons.
  8. HP Deskjet 3000 j310a Repair Printer Cover Replacement: 手順 8、 2の画像 1 HP Deskjet 3000 j310a Repair Printer Cover Replacement: 手順 8、 2の画像 2
    • Detach the wire from the printer by pulling the blue-sealed end from the white holder.
終わりに
作成者
3人の作成者と共同で作成されました。
tdambruoso
メンバー登録日: 10/20/14
491 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 1-5, Duarte Fall 2014 UMass Dartmouth, Team 1-5, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S1G5
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 34
今までの合計 462
