メインコンテンツにスキップ
HP Deskjet 1055 Scanner Glass Pane Replacement
必要な工具と部品
  1. HP Deskjet 1055 Scanner Glass Pane Replacement, Scanner Glass Pane: 手順 1、 1の画像 1
    • Take all paper out of the paper tray. Unplug the printer.
    • Remove the plastic printer-control panel on the top left.
    • Then, forcefully lift up the bottom of the panel while applying downward pressure with your thumb-as shown.
  2. HP Deskjet 1055 Scanner Glass Pane Replacement: 手順 2、 2の画像 1 HP Deskjet 1055 Scanner Glass Pane Replacement: 手順 2、 2の画像 2
    • With your other hand, slide the top of the panel towards the back of the printer.
    • Do not rip the white cable that connects the panel with the main body of the printer.
    • Disconnect the ribbon by pinching the blue tab and pulling away from the green circuit board.
    • Lift the panel free and set to the side.
  3. HP Deskjet 1055 Scanner Glass Pane Replacement: 手順 3、 1の画像 1
    • Place the plastic opening tool between the plastic cover and the mount on the printer.
    • Pry the plastic cover towards the center of the printer.
    • Pull up on the cover to remove it from the printer-as shown.
    • Repeat the process on the other side.
  4. HP Deskjet 1055 Scanner Glass Pane Replacement: 手順 4、 1の画像 1
    • To remove the glass panel, take out the four 14 mm (1/2 inch) screws with a T10 Torx screwdriver.
    • Don't lift the glass panel completely off because there are cables plugged into the underside.
  5. HP Deskjet 1055 Scanner Glass Pane Replacement: 手順 5、 3の画像 1 HP Deskjet 1055 Scanner Glass Pane Replacement: 手順 5、 3の画像 2 HP Deskjet 1055 Scanner Glass Pane Replacement: 手順 5、 3の画像 3
    • Disconnect the white cables from the green motherboard by pinching the cable where it connects to the green motherboard. Pull up, lightly.
    • Set the lower part of the printer aside.
  6. HP Deskjet 1055 Scanner Glass Pane Replacement: 手順 6、 2の画像 1 HP Deskjet 1055 Scanner Glass Pane Replacement: 手順 6、 2の画像 2
    • Place the glass panel, face down, on a smooth surface.
    • Remove the 14 mm (1/2 in.) screw from the white plastic tab on the side of the panel with a T10 Torx screwdriver.
  7. HP Deskjet 1055 Scanner Glass Pane Replacement: 手順 7、 3の画像 1 HP Deskjet 1055 Scanner Glass Pane Replacement: 手順 7、 3の画像 2 HP Deskjet 1055 Scanner Glass Pane Replacement: 手順 7、 3の画像 3
    • Remove the glass pane by carefully bending the plastic frame down from the side and sliding the glass pane out from the side.
終わりに
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Samuel Isbell
メンバー登録日: 10/09/12
10 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 9-18, Amido Fall 2012 Cal Poly, Team 9-18, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S9G18
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 38
今までの合計 3,863
