メインコンテンツにスキップ
HP Deskjet 1055 Ink Cartridge Replacement
必要な工具と部品
  1. HP Deskjet 1055 Ink Cartridge Replacement, Ink Cartridge: 手順 1、 1の画像 1
    • Turn on the printer by pressing the power button.
  2. HP Deskjet 1055 Ink Cartridge Replacement: 手順 2、 2の画像 1 HP Deskjet 1055 Ink Cartridge Replacement: 手順 2、 2の画像 2
    • Place your index finger in the opening on the front of the printer (right side below scanner/copier) and pull the door down.
    • Pull down on the tab that lies in the middle of the newly-exposed gray cover.
  3. HP Deskjet 1055 Ink Cartridge Replacement: 手順 3、 1の画像 1
    • The tri-color cartridge sits on the left side; the black cartridge sits on the right.
    • Grab the cartridge from the top and bottom and pull down until it clicks.
    • Pull out the freed cartridge.
  4. HP Deskjet 1055 Ink Cartridge Replacement: 手順 4、 3の画像 1 HP Deskjet 1055 Ink Cartridge Replacement: 手順 4、 3の画像 2 HP Deskjet 1055 Ink Cartridge Replacement: 手順 4、 3の画像 3
    • Take the replacement cartridge out of its packaging and pull off the plastic tab.
    • Do not touch the electrical contacts or ink nozzles. Touching may cause malfunctions.
    • Hold the cartridge on both sides with the title sticker facing upwards.
  5. HP Deskjet 1055 Ink Cartridge Replacement: 手順 5、 2の画像 1 HP Deskjet 1055 Ink Cartridge Replacement: 手順 5、 2の画像 2
    • Slide the cartridge directly into open slot (tri-color on the left, black on the right).
    • Push it forward until you hear it snap.
  6. HP Deskjet 1055 Ink Cartridge Replacement: 手順 6、 1の画像 1
    • Close the gray access door.
  7. HP Deskjet 1055 Ink Cartridge Replacement: 手順 7、 2の画像 1 HP Deskjet 1055 Ink Cartridge Replacement: 手順 7、 2の画像 2
    • Wait 30 seconds for the alignment page to print.
    • Open up the scanner lid and place the alignment page face-down in the right-front corner of the glass.
    • Close the lid.
  8. HP Deskjet 1055 Ink Cartridge Replacement: 手順 8、 1の画像 1
    • Press the color copy button to begin scan.
    • Wait until the power button stops blinking.
終わりに
When the power button stops blinking, your can now use your printer.
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Daniel
メンバー登録日: 10/06/12
314 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 9-18, Amido Fall 2012 Cal Poly, Team 9-18, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S9G18
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 24
今までの合計 15,992
