メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Deskjet 1055 Buttons Replacement
必要な工具と部品
  1. HP Deskjet 1055 Buttons Replacement, Buttons: 手順 1、 1の画像 1
    • Press your thumb down on the center of the button plate located on the left side of the printer.
    • Hook your fingers underneath the front edge of the button plate and pull upwards making sure to keep pressure on the middle of the plate with your thumb.
    • When pulling up the front cover make sure to keep your thumb pressed firmly on the cover plate and bend up the front. Not doing so will result in breaking the tab that holds the back of the plate to the printer.
    FixBotに聞いてみる
    コメントを追加
  2. HP Deskjet 1055 Buttons Replacement: 手順 2、 3の画像 1 HP Deskjet 1055 Buttons Replacement: 手順 2、 3の画像 2 HP Deskjet 1055 Buttons Replacement: 手順 2、 3の画像 3
    • Once the front of the plate is loose, lift it up a few inches making sure to hold the back (paper feeding side) of the plate down.
    • Slide the plate towards the back of the printer and then lift up on the back of the plate.
    • The plate should now be disconnected from the tabs on the printer.
    FixBotに聞いてみる
    コメントを追加
  3. HP Deskjet 1055 Buttons Replacement: 手順 3、 3の画像 1 HP Deskjet 1055 Buttons Replacement: 手順 3、 3の画像 2 HP Deskjet 1055 Buttons Replacement: 手順 3、 3の画像 3
    • Turn the plate over to reveal the white strip of connecting tape that connects the plate to the printer.
    • Find where the tape is connected to the green button circuit board (Location circled in red)
    • Place two fingers on the tape right where it connects to the plate and gently pull the tape out of the circuit board.
    FixBotに聞いてみる
    コメントを追加
  4. HP Deskjet 1055 Buttons Replacement: 手順 4、 1の画像 1
    • Place the plate down on a flat surface with the button circuit board facing up.
    • Remove the three(3) T-10 Torx Screws from the circuit board.
    FixBotに聞いてみる
    コメントを追加
  5. HP Deskjet 1055 Buttons Replacement: 手順 5、 1の画像 1
    • Lift the button circuit board up and off of the button plate
    FixBotに聞いてみる
    コメントを追加
  6. HP Deskjet 1055 Buttons Replacement: 手順 6、 2の画像 1 HP Deskjet 1055 Buttons Replacement: 手順 6、 2の画像 2
    • After Removing the circuit board you will be able to see the backside of the set of function buttons.
    • Lightly push each of the six tabs away from the clips holding them in.
    • Make sure to unclip all the tabs before pushing the buttons out of the plate. All the buttons are connected as a set and trying to remove them one at a time will result in them breaking.
    • Once all of the tabs are loose from their clips, push the set of buttons down and out of the button plate.
    FixBotに聞いてみる
    コメントを追加
  7. HP Deskjet 1055 Buttons Replacement: 手順 7、 1の画像 1
    • The power button is not clipped in and should easily slide off of the plate once the button circuit board is removed.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Matt
メンバー登録日: 10/09/12
88 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 9-18, Amido Fall 2012 Cal Poly, Team 9-18, Amido Fall 2012人のメンバー
CPSU-AMIDO-F12S9G18
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 40
今までの合計 2,522
