はじめに
When no paper is being dispensed from your printer, it is enough to drive you mad. If this is driving you mad, the Paper Roller Motor may not be driving anything at all. Save the stress and follow this guide to replace the Paper Roller Motor.
必要な工具と部品
Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
この手順で使用する道具:Tweezers$4.99
Locate and remove the two flat ribbon connectors which connect the circuit board to the other printer components.
Locate the paper control sensor.
Locate and unplug the connector which connects the sensor board to the main circuit board.
Remove the two 13mm screws with the screwdriver and a T10 torx bit.
Remove the one 9mm screw with the screwdriver and a T10 torx bit.
Remove the two 13mm screws which hold the paper roller motor frame in place.
ある他の人がこのガイドを完成しました。
