メインコンテンツにスキップ
HP Deskjet 1000 J110a Paper Control Sensor Replacement
必要な工具と部品
  1. HP Deskjet 1000 J110a Paper Control Sensor Replacement, Cover Removal: 手順 1、 3の画像 1 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Cover Removal: 手順 1、 3の画像 2 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Cover Removal: 手順 1、 3の画像 3
    • Remove the two 13 mm screws located on the back of the printer using a screwdriver with the T10 torx bit (star-shaped).
  2. HP Deskjet 1000 J110a Paper Control Sensor Replacement: 手順 2、 3の画像 1 HP Deskjet 1000 J110a Paper Control Sensor Replacement: 手順 2、 3の画像 2 HP Deskjet 1000 J110a Paper Control Sensor Replacement: 手順 2、 3の画像 3
    • In the front of the printer, open the tray where the paper comes out and remove the two 13 mm screws located under the top of the printer.
  3. HP Deskjet 1000 J110a Paper Control Sensor Replacement: 手順 3、 1の画像 1
    • With the front of the printer facing you, lift and raise the left side of the panel (like opening a book in reverse) until it disconnects from the clip on the right side of the panel.
  4. HP Deskjet 1000 J110a Paper Control Sensor Replacement, Paper Control Sensor: 手順 4、 3の画像 1 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Paper Control Sensor: 手順 4、 3の画像 2 HP Deskjet 1000 J110a Paper Control Sensor Replacement, Paper Control Sensor: 手順 4、 3の画像 3
    • Locate the paper control sensor.
    • You can find the sensor, with the back of the printer facing you, on the right, and in front of the main circuit board. The paper control sensor will also be attached to a small circuit board. You will be replacing this circuit board.
    • Locate and unplug the connector which connects the sensor board to the main circuit board.
    • Use tweezers if unplugging by hand is too difficult.
  5. HP Deskjet 1000 J110a Paper Control Sensor Replacement: 手順 5、 2の画像 1 HP Deskjet 1000 J110a Paper Control Sensor Replacement: 手順 5、 2の画像 2
    • Locate and remove the 8mm screw with a screwdriver and the T10 torx bit, then remove the paper control sensor board.
    • In this picture, the main circuit board is removed. It is not necessary to remove the main circuit board unless the paper control sensor is not the only part being replaced.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Colin Tourjee
メンバー登録日: 01/29/18
632 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S5-G3, Passmore Spring 2018 USF Tampa, Team S5-G3, Passmore Spring 2018人のメンバー
USFT-PASSMORE-S18S5G3
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 22
今までの合計 1,447
